Door displaying in 2D
I would like my door to display with the panel in the closed position but with the opening curve still visible. I've attached a screenshot of what I would like to achieve and what I currently have.
What I would like to achieve:
What I currently have:
I can manage to get the panel in the closed position by putting the opening angle in 2D to 0 degrees but then I no longer see the opening line, which is crucial...
Does anybody know how to solve this?
Best regards,
Vincent
Try using "Projected" as the 2d representation, leave the 2d opening angle to 90 degrees, and setting the 3d opening angle to zero.
Hope that helps.
Never mind... I tested that and didn't work.
Instead, go to MVO and set the Door 2d view mode.
That will probably do the trick.
