Door settings question
How do I change the orange color of the door? I searched through the settings and tried to change some of the cut surface colors but the color doesn't change.
1 Solution
Stress Co_
Change the settings in the Door's "Floor Plan & Section" settings.
See attached,
The "Override Object's Pens" box should not be checked.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Go to post
2 Replies 2
Stress Co_
See attached,
Thank you very much! I found it. It was quite confusing because both tabs were named Floor Plan & Section and I thought that the first one in the dialogue window refers to the door settings.
