Door with sidelight containing multiple opening sections
Hi there,
Im trying to get a door object that has a sidelight containing two opening sections and a fixed panel. The included archicad door object can be set so that there are 2 panes, both of which can be opened, but cannot have an additional fixed pane. am i missing something or is there a workaround?
i would like to achieve something similar as the image attached.
TIA[/img]
1 REPLY 1
matjashka
First, welcome to the forum, Shaun!
One way I'd recommend to approach a custom sidelight like this: create a custom panel for the sidelight. You get an option of a custom door panel and a custom sidelight panel.
https://www.youtube.com/results?search_query=custom+door+archicad
Note that once you have a basic understanding of how to script a parametric object (one that retains certain dimensions when overall size changes, instead of stretching like a rubber band), you can actually script a very flexible door or custom panel, with various automatic parameters. You can then use one "smart" custom panel regardless of door or sidelight size. Example: A sidelight panel that automatically increases the amount of glass divisions once the sidelight gets bigger.
Matt Krol [LinkedIn]
BHMS Architects and Planners, Chicago
AC 10 ... 26 USA
