luc2
Door
Hello everyone,
I hope you're all doing well ! I fine too
Please, how I can make this door in ArchiCAD.
Thanks,
5 Replies 5
David Maudlin
luc2:
Check your library. In the AC28 USA Library, the D2 and D2 Commercial doors have a parameter for changing the proportions of the two leafs.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
vistasp
Mentor
If you take the standard double door, you can choose (at least in the INT library) between uniform and asymmetric leaves.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
luc2
Ok. Thanks so much (ps : I'm french and I try to ask you without AI) so, I apologize for the mistake.
luc2
Thank you very much dear,
I'm grateful for your help with this screen who resume very good.
Thanks a lot,
vistasp
Mentor
No apology necessary. We're all here to help each other.
= v i s t a s p =
bT Square Peg
