Doors and Windows are all empty openings, objects not shown.
Archicad 12, All my doors and windows went from having parameters to just empty openings. Also my objects are shown as just dots. Libraries have been reloaded etc. Also, it takes a long time for the project to boot.
It sounds like it is still a library problem. Go into the library manager and check the paths are correct. If necessary remove the previously loaded folders, and re add them from the correct locations. A screenshot of the library manager may be useful to us too.
Is there anything being reported on the library loading report? (Go to 'Window'>'Palettes'>'Library Loading Report' to open)
Remove all the library and Add what you need again.
Your file lose the library. That why it shows dots at door/Window
Cheers
