Doors not showing
I have an issue were all the interior doors are not showing. But this is only going on on one computer. Everyone else sees them. Any Ideas?
1 REPLY 1
Are you aware that you are browsing just the AC9 SE subset library component inside what appears to be a project specific container file?
I assume that the door shown is the only one in that particular folder of the original library that was used in the project. Try the subtype view and you should see all the door types used in the project. For more parts load/browse the main libraries.
