a month ago - last edited a month ago
I'm using ArchiCAD 28 Studio on Windows 11 and have modelled the ventilation ductwork for a house.
Everything works fine except for the Duct Obstruction 27 object always defaults to "Rise" even after you select "Drop" anyone know of a fix?
Only thing I can think of is convert it to a morph and flip it over but I would prefer a fix to the GDL code if possible.
3 weeks ago
If this issue does not resolve, please report it to your local reseller.
3 weeks ago
You mention Archicad Studio.
Is that duct obstruction object a MEP object?
If so MEP does not work in the Studio version of the software as far as I know.
I believe you can see it, but you can't manipulate it.
2 weeks ago - last edited 2 weeks ago
MEP works in AC28 Studio. It doesn't work in AC29 Studio, sadly. They cruelly teased us with it in AC28 and took it a way again in AC29 is another way of looking at it 🙂
As I couldn't get it to behave so I resorted to converting it to a morph and flipped it over that way.
2 weeks ago
Laszlo, I referred it onto the reseller. They came back its been fixed in AC29 so it won't get fixed most likely in AC28
