Dynamic Roof pItch Identifier?
Do you guys know if there is a dynamic roof pitch Identifier out there?
for either section, elevation or plan?
2 REPLIES 2
David Maudlin
Jessica:
In the Object Depository under 01 General > Custom Labels there is a Label: ROOF AREA ,SLOPE,MAT. LABEL, which might work for you. I tried scripting a label to read roof slopes before, but it only read the slope from Single-Plane Roofs (not Multi-Plane) so the Label may be of limited value. You might also check the Bim Components web site.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thank You , I'll check that out, I only use single planes roofs, so hopefully it will work!
