Edit Database in ArchiCAD 20 Int.
Martin Jules
Mentor
Does anyone know where I could find the "Edit Database" into the document menu from the work environment of ArchiCAD 20 International ?
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
It is there under "All commands by theme". You should probably read the "Archicad Calculation Guide" in the documentation folder if you are messing around with databases - it is advanced stuff that I do not use.
Martin Jules
Mentor
Many thanks !
Martin Luther Jules
AC 10-28 (Full)
