kittonian
Beginner
Editing Object Parameters Gets Reset
I exported a 3D model out of C4D and imported it into ArchiCAD. I created a gsm file and everything works fine. The issue is that even though the dimensions are correct in C4D they are way off with this new object.
So, I am trying to edit the object and can only modify the zzyzx variable and get it to stick when saving the object. If I modify the A or B variables and then save, they reset themselves to the incorrect values.
What am I doing wrong?
ArchiCAD 25 | Cinema 4D R23
12-Core Mac Pro (2 x 3.46 6-Core Xeon, 64GB DDR3)
OS X 11.2.3
AMD Sapphire Pulse Radeon 5700 XT (8gb)
kittonian
Beginner
Nevermind. I converted the correctly sized object to a morph and re-saved it as a new object. All good.
OS X 11.2.3
