Elevator Object
Folks, I am attempting to use the SE9 elevator object. Looks fine in plan but 3d is not giving me what I am expecting - regardless of the number of settings I modify the object remains in a state that has no apparent rhyme or reason. The dialogue box has lines of text that don't fit the window and are therefore illegible. I can find nothing in the help files nor a substitute at Objects on Line. Help!
David Maudlin
Brian:
The right side of the dialog box can be resized. When both sides are visible, resizing the dialog box changes only the size of the left side of the dialog box. To resize the right side: click on the small arrow that is in the middle of the dialog box at the top (this closes the left side), resize the dialog box to get the width you want for the right side, then click this same arrow again to get the entire dialog box back. Now go to the Work Environment to save your Palette Scheme. This will at least allow you to see the parameter descriptions.
Hope this helps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David. I should have investigated the help file concerning resizing the dialog box but in the heat of design I was fixated on getting the object to function.
