Empty Door Opening
I copied the Empty door opening and added some settings so it would fit in with our opening schedule (arch height, opening type & notes). I'd like it to have "header lines" like the arch openings. They are the dashed lines in regular plan and solid lines in reflected ceiling. I tried adding them to the 2d symbol, but that doesn't work correctly. I want the lines to be on the outline of the wall. Any help would be much appreciated.
Thanks!
2 Replies 2
It is quite simple to script them.
LINE_TYPE "dashed"
Line2 -A*0.5, 0, A*0.5, 0
Line2 -A*0.5, -WALL_THICKNESS, A*0.5, -WALL_THICKNESS
Should do the trick. (Though you probably want to create a user parameter for the line type.)
That worked perfectly! Thanks!!
