‎2004-04-01
11:23 PM
‎2023-05-24
12:50 PM
Rubia Torres
‎2004-04-02 12:18 AM
‎2004-04-02 12:21 AM
‎2004-04-02 12:57 AM
Matthew wrote:Quitting and even rebooting didn't help. Selecting any casement window and then opening the parameters window also displays the error message. Arghhh! The windows display fine in all views--2D and 3D, however.
This is an internal error in a GDL script. I can't imagine how deleting a slab could cause it. There should in fact be no way that a user's actions could cause this error. I have to wonder if it is some kind of corruption in the temp folder/building model. Quit & relaunch might fix it.
Matthew wrote:Thanks--didn't know that. The lack of undo control is mindboggling. Even freeware drawing programs have better.
BTW the undo cue is not cleared by auto-save, but it is by a section window rebuild. VERY annoying and I really don't understand why![]()
‎2004-04-02 01:21 AM
‎2004-04-02 01:59 AM
‎2004-04-02 03:18 AM
‎2004-04-02 07:47 AM
Matthew wrote:No, that's true. They display fine. The problem is all the error messages popping up every time I draw a 3D or S/E window.
Oh, I should have mentioned that this particular error generally has no adverse effect on the display or modeling of the library part.
Matthew wrote:I get a paragraph of errors when checking the script. Would it be any help to post the errors? When following John's suggestion, do I save the part over itself in the same library?
Try John's suggestion, and while you're at it push the "Check Scripts" button and see if you get any errors.
Matthew wrote:It's the 8.1 library, without the v2 update.
BTW, are they old (6.5/7.0) or new 8.0/8.1 windows? Are they from the latest 8.1 library or an earlier one?
‎2004-04-02 08:02 AM
Dave wrote:I would recommend making a copy first then save over the original
‎2004-04-05 06:05 PM
Aussie wrote:I tried this suggestion also to no avail. Merging into a new and reset PLN hasn't helped. Short of deleting and re-creating all the errant windows, I'm not sure what else to try.
I know this might sound strange but open up the errant library part and resave it - reload library then see how it works
