Error message when inserting windows
Hi I am using the student version of archicad 9 I'm having a problem with windows from the library.
When I place a window then go to the 3d window I get the following warning message:
"File not found at line 201 of file casement_a.gsm"
Archicad seems to struggle for a minute and does display the window, but incorrectly, and the image flickers as if the program is struggling.
I tried installing the library update but it hasn't made any difference.
HELP!!!!!
0 Replies 0
