Fill angle
Probably it's to easy but... Why can't I change fills angle to 45 degrees???
poly2_b{2} 5, 3, penAttribute_1, penAttribute_2,
0, 0, 45,
-1, 1, 1,
-1, -1, 1,
1, -1, 1,
1, 1, 1,
-1, 1, 1
2 Replies 2
David Maudlin
Fotis K:
You need to add j4: local fill orientation to the frame_fill parameter (GDL Reference Guide page 144), so your code would be:
poly2_b{2} 5, 3+8, penAttribute_1, penAttribute_2,
0, 0, 45,
-1, 1, 1,
-1, -1, 1,
1, -1, 1,
1, 1, 1,
-1, 1, 1
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Notice that poly2_b{2} command is broken in 16, and still not fixed, nearly one year later.
In case of rotation or symetry, fill origin and orientation don't work.
It concerns all objects using this command, not only roof accessories.
