GDL Info Wish
Graphisoft needs to give us a clear explanation about the order that scripts are processed in, and which functions will be skipped under certain circumstances. I am having problems getting a LOCK function to actually trigger. It has been impossible to figure out what is going wrong -- the interpreter is getting to the line, it just won't execute it.
See the following thread for the source of this wish.
http://archicad-talk.graphisoft.com/viewtopic.php?t=7087
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Hi Jay,
Check out http://www.graphisoft.com/support/developer/documentation/LibraryDevKit/
Under Technical Standards/4.Script type specific issues you can find what you are looking for.
You can download the full Library developer documentation here:
http://www.graphisoft.com/support/developer/downloads/
Regards,
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
