GDL Unit problem?
Hello everyone! My GDL unit doesn't support decimal points, but I opened the previous file and found that the new file is invalid. I didn't find the reason.
David Maudlin
SL_GDL wrote:
Working units / Dialog boxes
Specifically Angle Unit.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
And here GDL?
David Maudlin
I adjusted the angle unit and the problem has been solved. Thank you.
