‎2009-08-14 08:53 PM
‎2009-08-19 02:12 AM
‎2009-08-19 02:35 AM
‎2009-08-19 02:56 AM
‎2009-08-19 04:05 AM
Erika wrote:You can REQUEST the height of the text once you have defined it.
Juha,
You jumped ahead to the anchor point problem. Some symbols have two lines of text. How do you keep them from running into one another when the scale changes? Or when someone changes the font size?
thanks!
‎2009-08-19 09:21 AM
‎2009-08-19 12:35 PM
‎2009-08-19 01:51 PM
Barry wrote:For one explanation of scientific notation, including the use of "E", see:
The E-014 as has been mentioned means add 14 more decimal places to the number.
i.e almost zero.
‎2009-08-19 04:23 PM
Braza wrote:Sorry for my being late but in the final production phase of AC13 I'm pretty busy.
The exponential numbers occur just with elements created using the special constrains (holding shift key to create orthogonal lines)...
I looks like the special constrains doesn't really locks the X as zero... but something very close to zero... which is that weird exponencial number.
When I use just x and y inputs to generate a line or an arc the autoscript code is clean... no weird numbers...
The ArchiCAD engine try to give the coordinate as much precision as it can... so it gives you that great number of decimals...
It would be great if someone from GS could give us some light here...
‎2009-08-19 06:41 PM
‎2009-08-19 08:50 PM
ztaskai wrote:So... Next tasks... Buy some boxes of Champaign and call that cool DJ, right?...
