GDL user interface bug
Rob
has anybody noticed that if you tried to change a library object's parameter with 'range' limitation from the user (custom) tab and you filled in a number out of the range the user/custom interface would disappear to the limbo-bimbo land and would not replace it by the closest number within the range limitation? I am surfing on AC 2256 (8.1R2/V2AUS).
::rk
1 REPLY 1
Rob
I have tested that on AC8.1AUSR1 and AC8.0AUSR3 and it did not work as well. Graphisoft any comments??? It seems to be a problem with RANGE argument in VALUE key word definition.
::rk
