Getting elements list from an object
Hi everyone!
I finally managed to create the object you can see in the image. I mean the panels that cover the walls of the building.
This cladding is composed by panels and substructure. My question is: Is it possible to get a list or quantify how many elements of each type are there (panels/aluminium profiles...)? The goal is to make it easy to get a budget of the cladding system.
Thanks!!
13 REPLIES 13
It's strange,
you say that with print the number of panels is correct during execution,
but what about the parameter?
if it stays at 0 you must go to parameter script and type:
parameters panels=panels
could it be?
ops i have forgotten a line:
parameters
It's strange,
could it be?
It worked!!! I didn't know about this function, thank you!!
Hello Joseba,
try adding this in the parameter script:
PARAMETERS panels=vert_panels*horz_panels
PARAMETERS
