SOLVED!
Glazing not showing in garage door
heathldesign
I have a stock AC library garage door and have selected a panel with a row of windows and selected clear glass for the windows but they don't show. in fact another door panel from the library will only create very thin slit windows no mater how many panels i choose. something is amiss with these objects.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
1 ACCEPTED SOLUTION
Solution
David Maudlin
heathldesign wrote:
...the widows show on the 3D preview, but do not show on the model in 3D.
Take a look at Door Settings > Garage Door Settings > Door Settings and Openings > Model Attributes > 3D Detail Level, try setting this to "Full", or if it is set to "by MVO" then check the MVO settings. The 3D Preview may not account for the MVO setting.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
6 REPLIES 6
David Maudlin
heathldesign:
It looks like the glass windows are placed only at the top of the door for these garage door panels, no option for top to bottom. You could create a custom panel.
David
heathldesign
Hi David,
for some reason the other pic attachments didn't attach. the widows show on the 3D preview, but do not show on the model in 3D. hopefully these have attached. the option for the number of glass panels per panel is greyed out and set to 5. there must be some reason why AC doesn't want me to change this, but it sure doesn't make sense. I did create a door but that was more work and redundant when there are objects supplied that should, but don't work.
heathldesign
for some reason it will only show one attachment, it accepted and uploaded two. anyway here is another object that clearly shows the windows in the 3D preview, but they do no exist in the model
heathldesign
and the second pics, since it won't upload two.
Solution
David Maudlin
David
heathldesign
Brilliant, that was it. Thanks so much, that was driving me mad.
Heath
