I've made a break line object with a masking polygon. I thought I was so clever by using GLOB_DRAWING_BGD_PEN as the pen setting for the mask. And it works great in ArchiCAD, the mask is completely invisible. Problem is if the drawing background is set to anything other than white in AC then the mask shows up in PlotMaker as a solid colored polygon. Now of course I could set the mask fill to white or use a dedicated pen and change that in PM. But I'm wondering if there is another way to achieve my original goal of an invisible mask in AC and PM while still allowing an off-white drawing background. I'm also curious if this behavior has changed in AC9. Thanks.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
