Learn more
archanom
Hatching in floor plan and section
Hello.  I have my new walls and elements in the renovation tool set to a hatch.  However,  I would like to see hatching of walls in floor plan, but not in section.  Is there a way to do this?
1 Solution
jl_lt
Ace
You can have a different graphic override in every single plan in the view map, either in plan, section, elevation and or 3d view.
Go to post
5 Replies 5
jl_lt
Ace
Hi, you can create a graphic override that has the fill of selected elements with any color and fill (hatch) you need.
archanom
Hmmm.  Well, I am not sure how to make a wall show differently in plan vs. section.  When I do a graphic override it effects both the plan and the section.
jl_lt
Ace
archanom
Thanks.  I hadn't worked with graphic overrides really.  I finally figured out the combination and that worked.  Thanks again.
jl_lt
Ace
Great!! it also took me a while to figure Graphic overrides out, but they work like a marvel.  Best of lucks!
