‎2008-08-19
03:11 PM
- last edited on
‎2023-05-24
12:42 PM
by
Rubia Torres
‎2008-08-20 08:10 PM
Krippahl wrote:No they weren't even in the beta as I recall.Matthew wrote:On the other hand, afaik, curved complex profiled walls did get stuck on 10 because they did not pass the Beta test.
Yes and no. A lot of future features show up in the special menu before they become active functions of the program, and the curved wall method appeared in GDL before it became available to the wall tool.
Still, the question remains. Why are those variables tucked in there?That, of course, remains to be seen.
‎2008-08-22 04:16 PM
‎2008-11-05 11:01 AM
‎2008-11-05 05:13 PM
‎2008-11-05 08:33 PM
Jocelyn wrote:You know that in the same way you want to put a New wall in the demolition opening, you can put a Demo wall the same length as the door/window with the door/window in it? Otherwise, with doors and windows on different layers, if you turned off the Demo doors how would you know where you had to infill the opening?
Re D/E/N windows....
I'd like to see that the windows and doors can be assigned to different layers from the walls they're placed in. If I could place a window on a demo layer, turn off the demo layer in the new view, and place a new wall segment in the hole in the existing wall that the demo'd window was in... well, that would work OK for me.
The idea of D/E/N parameters blows my mind a little bit. In a good way.
‎2008-11-06 01:26 AM
‎2008-11-06 01:29 AM
Stuart wrote:Exactly. But in reality if you remove a door or window from a wall there IS a hole to fill.
I would think that if the windows/doors were on their own layer(s) seperate from the wall and then you turn that layer(s) off then the window is no longer there to cut the hole in the wall, so there would be no hole to fill?.
‎2008-11-06 07:36 AM
