Hole shape after using 'empty opening'
hi,
Is there any way I could control the shape of the 'empty opening' ?
I have a window that has an arch at the top, but when I set 'empty opening' the hole becomes a square?
thanks!
i'm using AC14
David Maudlin
kielbasa:
The Empty Opening is only rectangular. To create a non-rectangualr opening, add a slab wi the ID "Wallhole" that is the shape of the opening. For more information see the Help files: Virtual Building > Parametric Objects > Graphic Creation of Custom Objects > Saving Custom-Shape Holes or Niches.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thank You!
vfrontiers
Also, there are other non rectangular OPENINGS in the library…
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
