John Edmundson
Hotlinked GDL imbedded Objects
is it possible to have a GDL object, with STORY sensitive coding, stay linked to the STORY levels in its PARENT file when the PARENT file is hot linked into another file with different STORY levels?
1 Reply 1
It might be done - but the object should have to be a "semi-automatic" one.
There should be a trigger to update the "story sensitivity"...unless switched the values loaded could stay untouched...
Just the idea.
Piotr
