is it possible to have a GDL object, with STORY sensitive coding, stay linked to the STORY levels in its PARENT file when the PARENT file is hot linked into another file with different STORY levels?
It might be done - but the object should have to be a "semi-automatic" one.
There should be a trigger to update the "story sensitivity"...unless switched the values loaded could stay untouched...
Just the idea.
Piotr
