Find the perfect object, manage libraries, create custom objects
Hotspots in macros
Hi!
I wonder if anybody knows if there is a way to not include 2d hotspots when you call, for example a furniture object, as a macro into another object (in this example a furniture group object)?
The result with all the hotspots is confusing at best and in worst case they interfere with move hotspots in the group object.
Andreas Åkerlund, Arkitekt SAR
Arkitekthuset Jönköping AB
ArchiCAD 5 to 25
Windows 10 64 bit
Intel i9 7920x @ 2.9 GHz, 64 GB RAM
1 REPLY 1
You can if you script it into your objects (if the option is not already there to turn of the hotspots.
In the object you want to call you have to add a boolean parameter to "Show 2D hotspots".
In this object you set this 'ON' by default.
In the 2D script you must then add an if/then control to each hotspot.
i.e.
if show_2d_hs = 1 then
HOTSPOT2 0,0
HOTSPOT2 1,0
HOTSPOT2 2,0
HOTSPOT2 3,0
endif
Now when you CALL this object you add to the PARAMETERS list of the CALL that this Boolean value is 0 (zero).
There by turning off the 2D hotspots.
The same can be done for the 3D hotspots if you want.
Of course if your Called object already has control over the hotspot visibility (some objects do) then you just need to add the correct parameter to the CALL statement.
