How Can I fix this error report??
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-11-23 08:57 AM
2007-11-23
08:57 AM
The next time I opened the file, I found a problem, an error report: name of data base duplicate (RoofMaker 2.1) in line 1 of file Master_GDLRoofMaker 2.1gdl.
I click continue, and need to click 3 more times with the same Alert as you can see on the attached image.
Is there any bug fixer to download? I tried http://www.archicadwiki.com/ and found it on earlier version, Bugs/Crashes with ArchiCAD 9 (build 1812) INT on MAC when opening old files.
And every time when I open this file, the same history.
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-30 09:49 PM
2007-11-30
09:49 PM
Ola,
I think that You have the mentioned "Master_GDLRoofMaker 2.1gdl" in the PLA-archive AND in Your built-in ArchiCAD-library. Both of them is trying to configure the same calculation database and thus generating the error.
Just expand the PLA and delete the file "Master_GDLRoofMaker 2.1gdl" and the errors should be gone.
Hope this helps.
Hope this helps.
