How to change the parameter name
Can you please help me on this. See attached
Regards,
Binoj
4 Replies 4
It should be the UI_DIALOG command in the Interface script.
Hi Barry,
Thanks for your reply.
But the Interface script looks empty when I opened. How to view the scripts.
Regards,
Binoj
That is why it says "Custom Settings" still.
Try adding this command ...
UI_DIALOG "Insert title here", 310,266
You can carry on and script a complete new interface if you want instead of having to use the parameter list.
Thanks Mate.
It worked well.
Really appreciate your support on this.
Also can you help me on the below topic as well.
http://archicad-talk.graphisoft.com/viewtopic.php?t=53216
Kind regards,
Binoj
