How to make door-window
I make door+window using floor plan & save as door object.
when i applied to the wall, the wall below the window disappear ?
how toavoid this ?
6 REPLIES 6
Aussie John
By default, the door and window tool creates a rectangle hole based on the overall A and B values. You need to include the wallhole command to describe the shape of your opening.
Cheers John
[/size]
David Maudlin
badakcentaur:
You will need to add a slab with an ID of Wallhole for the shape of the opening. For more information with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "custom window" in the search box, in the results list "Saving Custom Shape Doors and Windows from the Project File" will lead to detailed information.
1000
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Aussie John
Yes David likely to be correct as I misread and thought you were scripting the door.
Cheers John
[/size]
vistasp
David wrote:
1000
Ah, a senior moment. 😉
Congratulations!
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
ztaskai
Graphisoft Alumni
Graphisoft Alumni
I recommend you to look into the Creating GDL Objects ITG published by Graphisoft. It was created for AC11 but it contains basic stuff which remains true for a long time. There's a whole chapter about "Auto saving non-rectangular windows" in it.
Regs,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
David Maudlin
vistasp wrote:
David wrote:
1000
Congratulations!
Not my first one (or the last).
