I need custom LABEL
Hy
Sorry for my bad English!
I need custom LABEL i used one that is alredy in ArchiCAD (Generic label 20)
and all I need is ''Show composite/profile/material name''
butt i hate the two lines in pointer so can anybody make just one, pls? (picture 1.)
And also connection point I need just two (tree) (picture 2.)
in drawings are other ''labels'' it's just text and line so if anybody can hepl me or create label that i need i will appreciate so much Very Happy
tnx
2 Replies 2
I have moved this to "Libraries / library parts / GDL" as it is really a request for a custom label or about the controls of a library part.
"Working in Archicad" would have been fine as well.
There is no need to double post either - I will delete the older post in "Wishes" section.
That probably wasn't the best section to post in which is why you had no response.
If you get no response there is no need to post again - just reply to your original post so it gets flagged as new again.
Now in answer to your question.
You don't need the two lines.
You can place with one now.
Just use the "Detailed" geometry method and double click for points 2 & 3 (the second line).
See attached image.
As for the anchor point location of the line to the text the label only allows for the side - top, middle or bottom - left or right side depending on how you place the label.
It can't come from the bottom middle of the text.
I don't think this can even be solved with GDL scripting - which is why I moved this post here.
Someone that has tried might be able to answer.
