artktecture
In need of a triple sliding window X-0-0, not the standard X-O-X
Is there a way to adjust the standard archicad triple sliding window (W Sliding3) to show as X-O-O instead of the standard X-O-X? I'd prefer NOT to have to mask the extra slider symbol on the one side of the window on the elevations/sections/schedule etc, plus I like to have the openings show correctly in 3D.
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon [email protected] GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
5 Replies 5
Hello artktecture,
These two representations do not satisfy you ?
And you are right !
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
artktecture
Yes, the top image is what I need! Can you share the window settings you used?
Artktecture,
It's the first option about "sliding window"
First of all you have to choose how many part you want to slide : 1, 2 or 3
Christophe - FRANCE
Archicad 15 to 29
Eli Chiasson
Artktecture and Christophe,
I believe the issue is that artktecture is in Canada, and likely using the USA library. W Sliding3 in the USA library does not have the option to choose the number of sliding sashes.
The International library (which you are using Christophe) is much more flexible.
I have found a similar situation with sliding doors. The International library has many configurations but the USA library in some cases doesn't have a suitable object. I ended up getting someone to "convert" a few sliding doors from the International library to work with the macros in the USA library.
Artktecture, I'd recommend downloading the International version of ARCHICAD and looking at the objects there.
Eli Chiasson
Dexel Architecture
http://www.dexel.ca
AC19-23 USA+MEP • i7-7700 3.6GHz | 32GB RAM • Windows 10 Professional
artktecture
Thanks Eli,
I am using the W Sliding3 object from the USA library and will look into the international version.
