JGoode
Integer decimals in Outfield
For some reason when I set an integer parameter it displays 6 decimal points after the number. How can I remove these decimal points?
ArchiCAD 27
Windows 10
ZZ = 3 ! an integer
UI_OUTFIELD str ("% 0.1", ZZ), 10, 30, 25, 16 ! 1 decimal point
Or directly:
UI_OUTFIELD str (77, 3, 0), 10, 50, 30, 16 ! 77 is the number
Or you can make a request to the working environment.
Dform = "% 0.0" !!! integer
QW = REQUEST ("Linear_dimension", "", Dform)
JGoode
SL_GDL wrote:
ZZ = 3 ! an integer
Or directly:
What if I don't want any decimal points?
edit: Never mind, worked it out. Thanks very much!
ArchiCAD 27
Windows 10
