Achille Pavlidis
Is it possible to change tilt-turn window orientation?
Is it possible to change tilt-turn window orientation after it has been placed on plan?
As I understand the tilt-turn pane of the window is the opposite of the side that one clicks when placing the window. Since some times this needs to be changed, is there a way to do this without deleting and replacing the window???
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
David Maudlin
Achille:
I am not sure exactly what you want to do, but there are a few things to try:
1. Select the window and use the Rotate command
2. Try the "Flip" button under Preview and Positioning
3. Select the window and use the Mirror command on its center hotspot
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Achille Pavlidis
Thanks David!
Answer number 3 is the correct one, as it changes the side of the tilt-turn pane.
(The other two flip the window inside-out)
