Label Default Location
Wokka
I want to use a modified label for wall identification, but use the Archicad symbol arrow to point to the wall. How do I set the default position of the marker? The current location is too far away and I'd need to edit every instance it was placed. If it was a bit closer I could save a lot of work....
Cheers and thanks
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
13 REPLIES 13
Erika Epstein
You might try one of the labels in the GDL depository such as
Shape Label JM9 here
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Wokka
Thanks for the reply, but I'm happy with the label. Just it's default position is wrong. There must be a way of setting it?
Lumion 12.5/2023
D5 Render
Erika Epstein
Ah; why not save it as a favorite?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Wokka
It doesn't seem to work that way.
If I select my walls and then pick 'label elements', it applies the current label as determined by the label tool box, which is fine. The problem is there is nowhere to input the default offset position of the label if I'm using the archicad arrow.
I've copied a label to create my own and there is a 'hidden' parameter called "replacement vector" that will determine the position of the label, but only if I'm using the parts own arrow. If I'm using archicads arrow, the objects jumps to a different pre-determined position.
Cheers
Lumion 12.5/2023
D5 Render
Erika Epstein
Well, now I am totally confuse. Can you do a screenshot of what you want?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Wokka
That make two of us ; )
Thanks for taking the time by the way...
Attached some screenshots that may explain the issue better.
Cheers
Lumion 12.5/2023
D5 Render
Wokka
Next shot
Lumion 12.5/2023
D5 Render
Erika Epstein
Wokka,
Thanks for the screen shots; I understand what you want now. I personally haven't the skill to fix it, but plenty here like Peter Devlin, David Maudlin adn Frank Biester to name but a few can help.
I look forward to learning along with you.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Srinivas
+1
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
