2022-12-23
09:48 AM
2025-02-10
05:41 PM
Aruzhan Ilaikova
First of all sorry if the question is not understandable, because I want to draw a door like the one attached in the post which has a "tarja" (fixed part in the upper side of the door), but there's nothing similar in the AC Library..
¿Is there any door or object similar to the one I want in the library?
Solved! Go to Solution.
2022-12-29 12:32 PM
Hi Jose,
You can achieve the desired result by setting the object "Door with Transom". Please check the screenshots below (from Archicad 26). Hope they will help you 😉
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
2022-12-29 12:32 PM
Hi Jose,
2023-02-10 11:59 AM
Thanks a lot for your answer. I'm still in AC25 waiting AC26 ARM SPA, but the door library object is the same in AC25 and 26.
The solution is 90 % suitable but it still appears a frame between the higher and lower part of the door.
I replied your instructions in AC25 and 26 and the frame is still there
In any case it's much more useful than the way I was drawing those doors.
Thanks again
2023-02-10 05:55 PM - edited 2023-02-10 06:42 PM
AS @Rubia Torres has said, only i add few things as a workaround to achieve your targeted door, by adjusting the working units to be (0,0000) 4 numbers tolerance then adjust Transom frame width in Frame style & Dimensions panel to be ( 0.0001 m in my case ) then you can retrieve your default working units it will appear as 0 value:
