snow
Lift- and Sliding Door urgently needed
Hello all,
Does anyone know where I could get such one, with:
  • the stem, like in the image
  • and individuel adjustable dimensions for the profiles (like with general windows in archicad)
5 Replies 5
Hello snow,
I am not sure to understand your aim.
Are you able to share a front view picture ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
snow
Hello…
meanwhile I've made (with a lot of effort) a custom element.
I used the Library Part Maker to get a satisfactory display in the ground floor plan.
I'm glad that there is a way to do such thing.
But aside of the work to create the element, it takes always a lot of time to change the size of such window… it is not really possible to edit it in the windows menu.
So I still would say: "A lift-and-sliding-door" with all its possible different opening schemes belongs to the basic equipment of a CAD-Programm…
…because it is almost the basic equipment for every single family home here.
Thanks about these informations. In France I have never seen this kind of "lift-and-sliding-door" but I agree that it would be very interesting to have such an object included in the Archicad library. Maybe you could make a request to graphisoft in the section dedicated to this use?
Christophe - FRANCE
Archicad 15 to 29
snow
Christophe wrote:
... Maybe you could make a request to graphisoft in the section dedicated to this use?
I don't know where such a section is. Do you know… or someone else?
Hi snow,
Infinite Openings could achieve the exact geometry of your configuration using its "Sliding Door" type and I could create a custom symbol for your "lift and slide".
If you subscribe to the tool I could create an actual "Lift and Slide" door type that moves as per real life scenario.
Infinite Openings: https://cadswift.com.au/products/Infinite-Openings.html
You Tube Videos: https://www.youtube.com/playlist?list=PLcbNDcsCZtyr9OfByqKKMVylqG7SUjGDj
let me know if you would like to trial Infinite Openings.
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
