ivorhession
Loading Macro files
Hey all,
I am trying to import an object in to a project. Link below.
I can load the GSM file but it then asks me to load the Macro which i assume is the INT file - can anyone advise as to how you do this?
https://www.bimobject.com/en-us/internorm/product/internorm_lift-sliding-door_hs_330_modell-a
Cheers
Ivor
Ivor Hession
Principal
tóg_architecture
www.togatchitecture.com
AC28 Solo / Windows 11 / PC / AMD Ryzen 5 / 36 gb ram / Gigabit RTX 3040 /
3 Replies 3
It seems there are 2 files you need to download.
The window object itself, and an LCF file that contains all of the macros.
Both of these files need to be in your loaded library (or embedded library).
ivorhession
Hey,
Thanks for the reply.
That's what i cant work out how to do, its not letting me select the file type.
I have a library of objects on my hard drive which i have linked through the library manager but when i go into the Windows Default Settings the linked library is not showing in the navigation window at the top left, and i cant directly load the LFC file type into the embedded library using the Library Manager button at the bottom left???
Cheers
Ivor
Ivor Hession
Principal
tóg_architecture
ivorhession
solution found.
Needed to load LFC in to the embedded library i the library manager...
Thanks for the help.
Ivor
Ivor Hession
Principal
tóg_architecture
