ricarc
Localised Library and objects must be renewed...
I will explain you what the state of things in Italy now:
- Old located objects, made 15/20/25 years ago, in an extra library, especially made for Italian
way of building, now are a bit obsolete, but dead earlier a good GDL maker in Graphisoft Italy,
no more evolutions in this objects is possible now.
- International Library Archicad is "international" and used in a small part in Italy.
- Changes are so easy to do, sometimes, for example, simply the way to increase or decrease a
dimension of an object, without opening the settings window, but using modify dots...
- Objects were, and also now are, the plus of this software don't forget of it...
Operating system used: Mac Intel-based 13 Ventura
0 Replies 0
