Location Door Panel
Hi guys,
Does anyone know where I can find the folder-location on my computer of a custom door-panel that's being used in the model?
Thanks in advance,
Stijn
1 Reply 1
If it is actually working and you can see it in the model then it is either in the loaded library (check the library manager for the path) or the embedded library in which case it is part of the Archicad job file.
