GJWarch
Low Voltage Cable Lighting
Has anyone found any Objects for low voltage cable lighting?
Thanks
1 Reply 1
Hello GJWarch,
I use a classic spot. I propagate this object as a post of a railing. this makes it possible to size the distance between each occurrence or even to draw the wiring with the bottom rail of the guardrail. This low rail can be designed with a personalized profile.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
