Making a 2D object Stretch w/o stretching text
I've made a simple 2d symbol with editable text. Problem is the object needs to be stretched according to opening size. When I stretch it the text stretches with it. Is there an option to let the program know where to stretch the object. I need the text to be centered during stretch as well.
!   Name     : LINTEL CALLOUT.gsm
!   Date     : Thursday, November 12, 2015
!   Version  : 19.00
!   Written by ArchiCAD
mul2     A/1.905000, B/0.385027
add2     -29'-3.1876", -0'-5.9652"
pen     penAttribute_1
fill fillAttribute_1
poly2_b{5}       5,      2,      1,      3, penAttribute_1, penAttribute_2,
        0'-0.0000", 0'-0.0000", 3'-3.3701", 0'-0.0000", 0'-0.0000", 3'-3.3701", 0'-0.0000",
        29'-3.1876", 1'-9.1238",     33,
        29'-3.1876", 1'-0.8201",     33,
        35'-6.1876", 1'-0.8201",     33,
        35'-6.1876", 1'-9.1238",     33,
pen     penAttribute_3
line_property       0
line2    30'-10.4625", 0'-5.9652", 30'-10.4645", 0'-5.9652"
set line_type lineTypeAttribute_1
line2    35'-6.1876", 1'-8.9743", 29'-3.1876", 1'-8.9743"
set line_type lineTypeAttribute_2
line2    29'-3.1876", 1'-8.9743", 29'-3.1876", 1'-0.9743"
line2    29'-3.1876", 1'-0.9743", 35'-6.1876", 1'-0.9743"
line2    35'-6.1876", 1'-0.9743", 35'-6.1876", 1'-8.9743"
line2    29'-3.1876", 1'-2.9743", 35'-6.1876", 1'-2.9743"
line2    29'-3.1876", 1'-4.9743", 35'-6.1876", 1'-4.9743"
line2    29'-3.1876", 1'-6.9743", 35'-6.1876", 1'-6.9743"
pen     penAttribute_4
hotspot2 29'-3.1876", 1'-8.9743"
hotspot2 29'-3.1876", 1'-0.9743"
hotspot2 35'-6.1876", 1'-8.9743"
hotspot2 35'-6.1876", 1'-0.9743"
pen     penAttribute_3
fill fillAttribute_2
poly2_b{5}       5,      3,      0,      3, penAttribute_2, penAttribute_2,
        31'-7.8977", 0'-8.0744",      1,
        33'-1.4776", 0'-8.0744",      1,
        33'-1.4776", 0'-11.2173",      1,
        31'-7.8977", 0'-11.2173",      1,
define style{2}    "AC_STYLE_1" "Arial", textsize / 72 * 25.4 ,      0
paragraph		"AC_PRG_6"      2, 0'-0.0000", 0'-0.0000", 0'-0.0000", 3'-3.3701"
    pen     penAttribute_5
    set style "AC_STYLE_1"
        textline
endparagraph
textblock		"AC_TEXTBLOCK_6" 0'-0.0000",      5, textangle,  3'-0.2205", 3'-3.3701", 3'-3.3701",
        "AC_PRG_6"
richtext2		32'-4.6876", 0'-9.6459", "AC_TEXTBLOCK_6"
The code is at the bottom. When I made the symbol I also added a text contour line. This size stays the same regardless if there is more or less text. I need it to wrap with the text preferably with one or two spaces at the beginning and end of text. Here is a picture of what I'm working with.
0 Replies 0
