Material Texture Set Out Point
I have a whole bunch of materials created that have textures associated with them.
Now I want to use these materials in a library part, however I cannot work out how to set out the start point for the material. It seems to relate to the global co-ordinates as when I move the object, the texture position changes in relation to that object.
Can't work it out PLEASE HELP
6 Replies 6
You have to set the local origin of the texture internally in the GDL.
As I recall it is the COOR function. I also recall that it's a bit tricky but not bad if you are good at GDL.
Thanks Matthew,
I got the coor and vert commands to work, but it didnt really make sense. But it worked, so that's good. Thanks
Tom
David Maudlin
For anyone with the same issue, here is the code to set the texture origin, which is placed after the 3D command:
Base
Vert 0, 0, 0
Vert 1, 0, 0
Vert 0, 1, 0
Vert 0, 0, 1
Coor 2+256, -1, -2, -3, -4
Body -1
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
How do you move the texture then in this command?
Say I wanted to move the texture slightly to the right
Or does this relate to the 3D object?
David Maudlin
Tom:
To move the texture origin, add a transformation after the 3D model command but before the texture origin code (then delete this transformation after the texture origin code). For example:
_____________________________
Block A, B, ZZYZX
Add x1, y1, z1
Base
Vert 0, 0, 0
Vert 1, 0, 0
Vert 0, 1, 0
Vert 0, 0, 1
Body -1
Del 1
David
rocorona
For an interactive texture placing, try the following routine, but I find it is not so practical, unless you have many instances, each one with a different setting.
You have to define 3 new parameters (cx, cy, cz) in your object.
hid=0
HOTSPOT 00, cy, cz, hid+1, cx, 129
HOTSPOT cx, cy, cz, hid+2, cx, 2
HOTSPOT -1, cy, cz, hid+3, cx, 3
hid=hid+10
HOTSPOT cx, 00, cz, hid+1, cy, 129
HOTSPOT cx, cy, cz, hid+2, cy, 2
HOTSPOT cx, -1, cz, hid+3, cy, 3
hid=hid+10
HOTSPOT cx, cy, 00, hid+1, cz, 129
HOTSPOT cx, cy, cz, hid+2, cz, 2
HOTSPOT cx, cy, -1, hid+3, cz, 3
BASE
VERT cx,  cy,  cz
VERT cx+1, cy, cz
VERT cx, cy+1, cz
VERT cx, cy, cz+1
COOR 2+256, -1, -2, -3, -4
BODY -1
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
