Minigolf?
Estoy haciendo un proyecto que trata sobre un hostel, y mi grupo decidio colocarle un minigolf en la azotea, hay alguna manera de que pueda conseguir un objeto que sea un minigolf?
(Moderator edit: English Translation by Google Translate:
I'm doing a project which is about a hostel, and my group decided to put a rooftop mini golf, is there any way I can get an object that is a miniature golf course?)
3 Replies 3
En ingles por favor.
I've not seen anyone post with any kind of minigolf objects here... but there are some in the Google Warehouse:
http://sketchup.google.com/3dwarehouse/search?q=minigolf&styp=m&scoring=t&btnG=Search
You'll need to install the Graphisoft Google add-on to convert the downloaded sketchup file into an ArchiCAD object.
Thank you so much! And sorry about writing in spanish. But, there's one question I would like to ask you, when I tried to install the google sketch up plugin, it said it is available only for archicad 12 and older versions, and I use archicad 15. Is there a plugin for archicad 15?
http://www.graphisoft.com/downloads/addons/google_earth/Archivege_earth_connections_download.html
The confusing thing is that the download emphasizes Google Earth, but the add-on also converts SKP files to objects (gsm).
The earlier add-on that you mentioned tried to convert sketchUp elements into ArchiCAD elements, rather than objects.
