halzsa
Missing Attributes in Library Elements – Teamwork File / Educational Version
We are experiencing an issue with missing library elements in an Archicad 29 Teamwork project.
Some library elements are missing their required attributes, and we are not sure how these attributes should be loaded or restored. The elements themselves appear to be missing or incomplete because the related attributes are not available in the project.
This is a Teamwork File, and we are using an Educational Version of Archicad 29.
Could someone please explain how we can properly load or restore the missing attributes for these library elements? We would also like to know whether there is a specific workflow for handling this issue in a Teamwork project.
10 Replies 10
halzsa
The issue has been resolved. The image was taken before the problem was solved. I was meant to show that the libpack had no file size. Sorry for misleading.
Once again, thank you everyone for the help!
