Need help with 2D script
Hi
I have problem with my object. My friend had made me script for some object but it look it is not finished and i have no contact with him.
I need help with 2d script and parameter script.
Now i have one txt file in witch i can put dimension for automatic drawing of 2D. When i select it from library I can chose in parameters if i wish to draw with database or without. when i select with base i can select what i want base or crossection ( it is all in 2D but i don't need 3D). And i can put data in that txt file but it only select last data and draw it by last data from txt file. I need help from you people to help me change that script so i can put in my txt file for example 4-5 different data and i need to add question for examp. from witch row to select data before it draw my object.
If anyone want to help me it would be grate i can send you object and all data on email. my email is djzoran@sbb.rs
Hi Zocca
Zip it up and post it here.
You can't post a .gsm directly.
One of the generous gdl gurus on this forum might just take a look.
Or of course you can, as you suggest, wait for someone to email you.
lec
I would be happy to help.
