Non-symmetrical sliding glass windows?
Is there a way to modify the standard sliding glass windows to not be symmetrical? I’d like to do an 8’ wide window with a 5’ wide fixed glass section and a 3’ wide sliding section. I don’t see it in the standard sliding window object, and all the “Feature” windows are awning style, which confuses our window vendor. What do you recommend here?
I’d like to avoid making a custom object. Thanks!
1 Reply 1
I've moved this post to a more appropriate section of the forum.
If the standard object you are using does not have an option to adjust the sash sizes (sorry I don't use the standard Graphisoft objects so can't say if they do or not) then you may need to look for a third party object.
