Object Configuration
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-09-13
03:16 PM
- last edited
2 weeks ago
Aruzhan Ilaikova
We use an object that has a configuration of being able to drag and the object multiply. - part of this object allows us to add a number to each multiplied object. Example down below:
We go by the standards of having four digits at all times I.E 0042 but at the object will only allow this for the first object and the rest don't allow the 00. We can change it manually but obviously the aim is for it to be automatic.
Is there any way to change this?
Below is the object settings where we add the value
Thanks so much for your help!
- Labels:
3rd Party Objects
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-09-13 04:13 PM
You will need to edit the object code to change how the object formats the numbers / text. If this is a commercial object then you will need to contact the author/supplier.
