Object Parameters in Labels
[Pardon the length of this. I'm posting it in chunks to reduce fatigue. I hope answering is easier than asking!]
The big topic is having a label display an object parameter's value. The specific goal is labeling a structure member in section. Here goes...
Structure member documentation Requirements:
• Display in plan with descriptive text
• Model in 3D to proper dimension based on size/specification and unit quantity.
• List by descriptive text
• ID is used to key in calculations.
• Label in section.
Current solution:
parameters:
mem_typ (ABC, Name of the shape)
qty (Int, Number of members)
The object contains dimension data for various shapes.
The plan is no problem. The member can be drawn as a line, or as a rectangle of the proper width, calculated from unit quantity x unit width. The descriptive text is a string, built from the quantity and specification/shape. It is not a Label element.
The 3D model is also finished, it's merely the right number of shapes of the right size.
To list the members, a parameter is needed, "desList". (In my libraries, "des" means "designation". I use this for any object that has to assemble its own description.) This parameter is filled by a PARAMETERS statement: PARAMETERS desList='('+STR(qty,1,0)+')'+mem_typ. It is simply the parameterization of the descriptive text string in the 2D symbol.
The ID is put in manually. It rarely changes. The ID number refers to a specific instance of a member, not to a configuration of size/quantity. The size/quantity may change, but the ID will stay the same.
Labeling in section is done manually. In the past we used a text block, now we use a text label. This the problem area. Every member has to be labeled in every section. Change management becomes prohibitive and risky. I can't use the ID, since not every member has one, but they all need to be called out. This leads to the new requirement...
James Murray
10 Replies 10
Domagoj Lukinic
Hello there! Any changes to this issue?
I am trying to do the same thing to have a label that reads object variable.
